as i say my system now isLuffy said:Hi
Are you planning to overclock? If so go for the Core2Duo, but you need to consider better graphics if you play lots of games as you say.
....cant believe you dont understand what im doing..im buying a new computer....a whole new computer.. i cant chose wether to have the hardrive or notjaykay said:why do u need another hard drive lose the hard drive and get a better graphics card as the 6200 performes the same as the 7300
with the core 2 duo u will need a new mobo and with the amd as you specing a am2 core when u have a s939 core
AmateurJimmy said:....cant believe you dont understand what im doing..im buying a new computer....a whole new computer.. i cant chose wether to have the hardrive or not![]()
Just what i thought. Get something like the above and you'll be laughing.goody_106 said:Get something along the lines of :
Gigabyte DS3
E6400
1gb/2gb DDR2 Ram
Nvidia 7600 onwards or maybe x1950 pro
Exactly what I did so speaking from experience![]()
ah thanks, very very helpfull cheersgt_junkie said:And for a measly £40 more - worth it as the x1950pro is a stonking card!![]()
If you've got the cash it may be worthwhile going for the 512mb version as a lot of the newer games will begin to use up this kind of space!
Happy shopping mate!![]()
gt
the e4300 is only 1.8ghz thought that was badAmateurJimmy said:ah thanks, very very helpfull cheers
AmateurJimmy said:the e4300 is only 1.8ghz thought that was bad![]()
The trick with the e4300 is that it has a higher multi than something like the e6300. That means that the mobo and memory you get won't necessarily have to clock as high! e4300's generally get to 3ghz quite easily and i've seen some at 3.2ghz+.AmateurJimmy said:the e4300 is only 1.8ghz thought that was bad![]()
Quite right! The DS3 is one of the best budget clockers you can buy! You'll get a 50% overclock at the very least i would have thought.Nymins said:Overclock it.
