Jasonp said:Might try some arctic silver see if it helps, just about the only thing i haven't tried so far using the stuff that came with the AF7 atm.
paul_64l said:off topic i know... but is there anything like tat for nvidia chipsets as tat wont work on my rig.. i use coretemp and im getting 35idle 65load
chriscatt said:Hi, well I'm sorry you think that the pictures I have posted are some kinda setup. It is the truth, this CPU is doing great things running at a vcore of just 1.18. It is solid, stable and is running those temps. If you don't believe me then there is not much else I can do unless you can suggest some other means by which I can convince you. Here is another screen dump taken after the PC has been running for around four hours, the ambient temp of the room is 24c, this time using everest. Think about it, why would I bother to concoct a story?
ChrisC
, I'm using AS5 which I've re-applied a couple of times in the past and the temps seem to stay the same, heres my setup,lowrider007 said:dude I don't think your lieing mate, I just did'nt think it was possible, I thought mayby TAT was giving false information, if it really is possible to get temps down that low on air then I think I'm gonna have to start playing around with my E6300's cooling then, according to TAT my 6300 @ 2.6 on stock volts idles around 42C with ambient room temp @ 24C, playing farcry it edges upto 65C, now if you guys are giving correct temps which it looks like you are then I'm not a happy chappy, I'm using AS5 which I've re-applied a couple of times in the past and the temps seem to stay the same, heres my setup,
P180 with front 120mm intake fan, rear 120mm + Top 120mm fan
E6300 with Scythe Mine - http://www.scythe-usa.com/product/cpu/023/scmn1000_detail.html
It's not stable your OS could get corrupted at any pointchriscatt said:Hi, what makes you sate that 1.18 is phoney overclock, I meant phoney? If I am running at 3ghz on a vcore of 1.18 and it is stable and cool what is phoney about that? There are other posts that have the same claims in this forum.
I'll tell you what I'll run orthos and see what happens, however, to my mind, if it is stable with what I do then it is stable enough. If it can run Farcry at it's highest settings, Stalker too, and never have one issue, then in the real world it is stable and it is orthos and prime that is phoney...
ChrisC
EDIT: As I expected orthos failed after about 3mins, but do I really care?
ChrisC
C64 said:It's not stable your OS could get corrupted at any point
that's why people use orthos and prime for data integrity.
