Suppose i could always apply the finger test to the base of the tuniq.
If it burns it's too hot![]()
@ Deluxe1, was Coretemp 'broken' before the bios update?
I remain to be convinced!
It might be the cure for some problems, but I'm not sure how the bios can impact what temps are being reported by thermal resistors in the core of the CPU?
I can see how a bios upgrade might change the reported socket CPU temp, as that's calculated via an algorithm I believe, so they could change that.?
Coretemp readings havent changed since my bios update,they still seem to be stuck on 45c whilst idle.
Speedfan and the rest have,i used to get 17c for my idle temps,i`m still not %100 sure what to believe tho concerning my temps.
Because the BIOS is still the Input, Output system. It can be innacurate still.
My temperatures changed around 5c on Core Temp when Asus tweaked the CPU temp readout with a new bios.
