Depends on the ones you get if they are designed for the e92 then they will work fine with no error codes. I am not keen on the yellow look angel eyes, my LEDs work fine and no error codes. Just putting any H8 LED bulb in can end up with the cost of a new light module. It is a 5minute job to change the bulbs as long as you have small hands . . . . took me longer though.![]()
Any tips on where to source ones designed specifically for the E92? When i get the problem fixed i would still like the white rings! It looks like i bought generic ones which have damaged either the wiring or light units themselves.
