Easyrider's Journey Into Phase...
Caporegime
24 Dec 2005
Autonomy
The phase unit I bought has gone back for modification....Basically to silence it.
This is just to give an idea what I'm doing....
The phase is having a new top on it with a new hole cut and the line is being lengthened.
The line will come in behind the PSU
The fan grill is going and it will be replaced with a black one.
A side window will be added and I might powder coat the inside of the case.
furnace said:
Awesome :D
What does powder coat mean?
Its a way of painting it. The surface it electrostatically charged, a powder paint is then sprayed on and the the whole thing is finally baked to attach the paint.
Nice setup easyrider. Not as good as mine though. :p Whats Gray doing to silence it you know?
Yes its not as good as yours lol.
Not spent as much as you lol ;)
Hes changing the compressor,twaeking the gas and fans,
It will still have superior performance to that of a Mach II or vapochill though but with very low noise, :D
weescott said:
Mine will be nicer when it's finished :p
Easyrider...specs please!!!
What of?
The phase?
The Idea of using the P180 is to have a super Sleek silent Black towering monster.
:D
looks great!
Keep us updated with lots of pics :cool:
P.S: I really wanted that case I just thought I would cover it in fingerprints, I noticed you didn't remove the plastic coating yet! :D
Big.Wayne said:
looks great!
I'll be drilling the case etc....
Leaving it on for protection.
@Gangster if you pass by....Thanks ;)
easyrider said:
Well it was the noise factor.
But that is being dealt with :D
Must have been pretty loud before. Good choice I think, sounds like a great unit. As long as you don't sacrifice too much performance.
I have been assured it will have vastly superior performance to a Mach II and vapo :)
Gray should do a nice job for you mate, running one of his modded Mach1's which was built as a "quiet" unit.
Pretty noisy pulling down to ~ -40 or so but after that the noise level's MUCH nicer. Still not silent/quiet by anymeans but much better that at full whack!
This unit runs ~ -58 no load (evap) and -47 evap @ idle. Evaps sat at -43 right now, with CPU (E6600) @ 4.2ghz w/ 1.6+ vcore. It's tuned for "quiet" running, but still packs a punch. Kudos to the master :D
