Hi Guys,
Longtime lurker, first time poster. Looking for some assistance from the seasoned veterans please.
I just completed my loop consisting of 1080ti full block, Asus Maximus Hero IX Monoblock, D5 Res/Pump Combo, 240 SE Rad, 360 SE Rad all joined with PETG hosing. Order is Pump -> GPU -> CPU -> 240 Rad -> 360 Rad -> Pump again.
GPU temps are perfect at 19'C idle and 32'C loaded. CPU on the other hand is idling at 40'C and spiking 80'C loaded. Chip is a 7700K with 1.2v. As a reference, my previous H115i AIO kept the same clock at 32'c idle and 61'c loaded.
I initially applied Thermal Grizzly to cpu, then when noticing the temps, removed the block, and could see there was contact between the block and cpu, and applied the standard EKWB paste and refitted the block. There was no change in temps at that point. Also note there are no bubbles or trapped air in the system.
Any ideas what the hell is going on here. Is this block faulty?
@EK Luc
Thanks in advance!
https://preview.~ibb.co~/mzTxWk/IMG_0886.jpg
@EK Luc
Thanks in advance!
