Guys I went from 24fps in dense grassy areas and forest to 37fps!
Turn off shadows on grass (only stops your shadow casting on grass) for 5fps.
Go into the oblivion ini and change iMinGrassSize=80 to =160 for 8fps
lol wtf?speeduk said:
nikebee said:lol wtf?
any screenies or anything... excuse the n00bness but what does it do... i mean... what do the pets do![]()
hahaspeeduk said:They work like summons do for the conjurer. They follow you around and protect you if you are attacked etc. They also grow in size every 5 levels.
If they get lost or stuck you have a "bone" to call them to you.
nikebee said:haha
is the mod easy to install/uninstall?
if it sucks or gets annoying i'd hope its easy to remove
I did have a slight problem with the arena guy once, but I just unloaded a few mods and start it again worked fine after that. One tip is not to load any saves with new mods in the middle of a quest, also to ignore the irems may not appear box it goes once you load up a new save game with the new mods in.speeduk said:They work like summons do for the conjurer. They follow you around and protect you if you are attacked etc. They also grow in size every 5 levels.
