- 19 Oct 2002
- Shakespeare’s County
I don't understand the whole battery rental. Seems to wipe out all the savings and then some.
Its only Renault who offer it anyway.
The battery in the Leaf has an 8 year 100,000 mile warranty.It does. If your not doing many miles it makes it more expensive than running a petrol car. But then if your doing lots of miles, a Leaf doesn't have the range.
But if you don't pay it and the batteries die, your looking at an 8k bill lol
You kind of have to be in the narrow window where it's cheaper than petrol but not doing too many miles. A bit limiting tbh. Don't forget you'll also be paying for the actual car on top of that, which depreciate like yesterday's ****.
There are taxi firms and driving schools out there running around with well over 100K and no issues.
The batteries have been very robust so far, a completely overblown point by scaremongers.
I pick up my Nissan Leaf tomorrow morning, it's a work commute car for me replacing the LS430.
I'll be charging overnight on the 'granny' lead (household plug), will post a thread up once I've had it for a bit.
I went for a 30Kw Tekna 3.3 Charger as no point paying £500 to charge quicker overnight and if I do charge away from home it'll be a rapid charger.
.I pick up my Nissan Leaf tomorrow morning, it's a work commute car for me replacing the LS430.
What does your effective MPG work out as?I've just switched to a Kia Optima plug in hybrid.
31 mile range on the electric motor, then a 2l petrol engine that runs in hybrid mode. I've had it a week now and although it isn't an engaging drive in the slightest, the range seems to be real world rather than theoretical and it works for my mileage.
I do ~10 miles daily for the work commute, and much of my driving is well within the electric range. I also do a couple of 200 mile trips a month to the hybrid option works well there too.
I don't think a pure electric car would work for me as the range would be an issue. Hybrid seems to be a good choice at present.
The new leaf? I quite like it, which i can't believe..
Thing is you can get a larger car, petrol and decent support for less than the £16K + rental that the Leaf costs. New tech pricing to fund R&D vs optimised for the petrol. It's priced so Nissan helps itself to the saving you get from road tax over the life time of the vehicle on purchase.
The pricing of electric leaves me both annoyed and frustrated. Seems that 3 years down the line that should change.
It's crazy how quickly they depreciate as well. After 3 years it will be worse less than a base spec Focus.
On the up side you can buy a 3 year old, low milage one for less than a base spec Focus! lol
It depends how you measure depreciation. The MSRP on EVs is often crazy. As a result, depreciation versus MSRP is huge. Depreciation against the best available prices isn't too bad. And EVs do seem to have something of a price floor. The depreciation really tapers off after a few years. The prospect of cheap motoring means it's difficult to find an EV with an owned battery for less than £5k, regardless of age or mileage.
Well, an almost 30k Leaf will be worth under 10k after 3 years. A 20k Focus is around the same.
If your buying a used EV, prices are great (assuming no battery rental, which destroys any saving in running costs).
