Man of Honour
- 29 Mar 2003
- Blurton
Surely it depends on the size of the oven. Ours is wired in the way you describe, it was done by someone who has nigh on 40 years in the trade, some of it substation, he really does know what he is on about. I will be seeing him shortly and asking him about this, as you seem to also know what your on about.
Actually I don't know what I'm on about (true).
If we were testing individual elements and motors on a bench then we would have a 13amp plug with normal wiring and crocodile clips on the connections and just put these on the items and switch on to see if it heats up or the motor turns.
In a double oven cooker there can be up to 3 elements (depending on model) in the main oven (sides, back or top) add to that another element or two in the top oven and you have quite a bit of ampage building up that a 13 amp socket will not handle.
I think the ampage on an hob was 7, 6, 5 & 5 so that alone needed 23 amps if all were turned on to full.
Ours has one element (it's reasonably old) and a gas hob. he did state that if we were to get an electric hob and turn everything on at once then it would have to be hard wired on its own breaker.
