Yep excellent shave from them. Be aware it does take awhile to get used to it, your might blotch a few times.Have a look at a Braun series 9 with the self cleaner. I found mine to be excellant.
So hot for you right now but Feather Hi-Stainless Platinum or GTFODerby blades held by the teeth of my partners mouth, lights off.
I have a beard trimmer, looks more like a pair of clippers.Are they any good?
Looking for a decent one i tried a rechargeable in the past but it was useful nevee held a change and was always getting snagged by it
the only time I tried the real shavers with the multiple rotating head things it was more like pulling than cutting. put me of them for life
well it was like 2002 but it was an expensive one someone got me as a birthday present, I think Philips or Panasonic were the manufacturer.Never had that problem with rotary heads myself, and my facial hair is really tough. Foil shavers though, well that's a different matter entirely. Absolute agony.
I use a Phillips Oneblade, does a decent job and quick, depends what you want to achieve.
This comes up every year:
I've got the Braun series 9 as suggested above but also own the Panasonic ES-LV65 which thrashes it. In fact, nothing beats it:
https://www.amazon.co.uk/Panasonic-...21&hvtargid=pla-565384449738&psc=1&th=1&psc=1
