stick klipper on it. some rails and the endorphin mod. you'll get some better speeds. iirc prusa defaults to 40? default can do at least 80/100.Well ive been trying the ender 5 out on dome prints and also the prusa slicer, all seems to be going well just need to work more to get the speed up now.
Prints all good but quite slow with default prusa settings.
looking at the rest of the bits for zero G it's something I'd love to do but realistically it's a lot more involved than the endorphin mod.Depending on the length of the rails you have I'd really recommend doing the Zero G Mercury. I converted my ender 5 over a year ago and it's awesome, quite the change from original.
nope, just a bit of config and all good.just wondering was it hard to set up accelerometers?
if you've a Pi already then it's _super cheap_ the ADXL345 just needs wiring in then some code from klipper.I am trying to get my calibrated "manually" first. If that doesn't work I will try accelerometer method
Have no idea.. But all of my ringing and ghost is gone nowthat's an odd peak at 125 lol, what's going on there?
Hmm it resonates at such high frequency? Hmm have compared this to other printers?so, new post rails and new cooling ducts here's my resonances -
https://i.~ibb.co~/x1hj7tM/shaper-calibrate-y.png
https://i.~ibb.co~/RSHph5P/shaper-calibrate-x.png
not sure why mines an order of magnitude more? or am I reading it wrong?
though the acceleration is WAY higher?
