- 27 Jan 2005
- S. Yorks
Wow, what speed was that at - good work by the way.
I forget what speed that was, I've found that I can get 450mm/s at 10k accel without the table shaking itself to bits.Wow, what speed was that at - good work by the way.
I still fancy doing this conversion to my printer, do you know of any kits as I just want to bolt on as opposed printing everything out.so I've moved house and now the printers on the floor rather than a wobbly table it's vibration/shake is way better. I'm able to do 550mm/s at closer to 15k accel.
I'm not sure if I'm going to do hydra at this point but I'd like to if only to get a better print bed on here.
I've noticed that I'm getting worse adhesion now I'm in a space that has way more airflow so I'm half tempted to get some kind of enclosure or build something around the table it's under.
There's some places that do on AliExpress etcI still fancy doing this conversion to my printer, do you know of any kits as I just want to bolt on as opposed printing everything out.
