andi said:Powerstation themselves admit it's "designed to measure power at the flywheel" and not accurate at the wheels![]()
paradigm said:So, by taking all its measurements and readings at the wheels, you are saying its more accurate at obtaining flywheel figures, something which the RR doesn't have any direct dealings with![]()
Will Gill said:id be impressed if I get 200 at the wheels, 300+ at the FW and ill be a happy chappy
Jonnycoupe said:Powerstation has two huge rollers the car needs to drive, one measures the torque applied to it and then the other is used to calc wheel coastdown losses in order to make a more accurate flywheel figure. So the wheels figure tends to be much lower than other Rollers and indeed the power at wheels you experience on the road.
Although saying that PS read 5% over if you ask me.
Gibbo said:You've lost me there m8 as what your saying seems to contradict itself?
On one hand are you saying PS rollers should show less BHP at the wheels than your actually getting down to the road but on average still give results 5% higher than other? So in essence all rolling roads give low figures at the wheels just PS not as much?
Is their flywheel figure accurate? How do they work it out as all cars are different? I believe my car loses 12-15% through the transmission from reading the US forums...........
andi said:I believe he means the flywheel figures are still 5% over![]()
L0rdMike said:http://homepage.ntlworld.com/l0rdmike/Car/L0rdMike-ToyotaMk1MR2.pdf
What I got last year. Is the loss from fly to wheels average?
Jonnycoupe said:MR2 is essentially FWD in terms of losses.
[TW]Fox said:If I was running I would get 210bhp at the wheels becuase I filled up with Optimax last week.
:/Vanilla said:I hear honda have never had a VTEC engine come back. You considered one of them![]()
you considered a career in comedyVanilla said:I hear honda have never had a VTEC engine come back. You considered one of them![]()
