- 25 May 2008
- North Wales
I had a custom map on my old Impreza, went from 265 to about 320bhp and was very noticeable, car only had a couple of mods like a big catback exhaust, panel filter and uprated fuel pump.
Mine was all done custom on the Dyno as i wanted it to be safe as i was tracking the car quite a lot at the time so wanted to make sure everything was all good through the rev range with AFR's etc, i did probably 25-30k in the car after it was mapped including about 10 track days and a trip to the 'ring in Germany without any issues.
Proper remaps are brilliant things if you understand the extra strain it can put on components and any weak points in your particular car. Like with mine it was generally accepted good idea to put in a better fuel pump as the last thing you want is it leaning out at high boost and was a cheap and easy DIY mod before the map.
