Variable Valve Timing and Lift Electronic Control isn't one word.
VVTL-i
Yet its perfectly fine to restrict small vans?
lol so then what of your average driver?
So you've said it would be dangerous to limit to 70 incase one needed to overtake. So why not raise the limit to around 80 or 90. No car needs to go above 140
VVTL-i![]()
On a similar subject what is the average engine size sold around 1990 and today? Was having this discussion a while ago with a friend and I suggested (completely without evidence) that the average engine on the road today was around 2L.
The 350Z engine started off as a Renault engine
Are you sure, I thought it was a higher capacity version of a Nissan VQ30DE unit that Nissan used way before the Renault partnership.
I don't see a problem with car makers down sizing hot hatches etc, its mainly done for emissions more than anything, most manufacturers will always make a v6 or v8 for top end models anyway.
I would guess that the average size today is definitely less than 2.0L.
Tomorrow on your way to work, count the number of hatchbacks and probably 1.9TDis. Even those newish A5s that the reps drive are mostly 2.0T or TD.
EURO 4 emissions
VVTL-i![]()
Isn't that what killed the 2zz and the high rev Honda engined so the reason for changing to low displacement high technical didn't pay off as they have been killed too.
But take Ford for example, after the Cossies and the RS Turbo escorts they went for a reasonable amount of time before they introduced the turbo back into the range proper. And it still hasnt filtered down to the fiesta, or filtered its was up to the Mondeo, which had to make do with one of those V6's i talked about instead of continuing development of those turbos that were already in the market place.
GRRR!
Sorry I mean EURO 2.
