Looks good pal - is this a better solution than more solid engine mounts?
There has to be movement or things Snap. Torque dampers control the movement.
Few guys on the ATR forum have these fitted, they found the same thing as you: Less wheel hop but more vibration. One guy actually ended up removing it because the vibration really annoyed him.
Loads of it - at the wheels![]()
do u have O.E engine mounts?
i found that fitting "solid" mounts into my car made a world of difference to the feel at the front end and although you do get a few more vibes coming through, raising my base idle to a solid 800rpm when warm fixes the issue...
