- 30 Jul 2007
Ive got to the bottom of it and my bios is showing on PJ (albeit having to press del/f2 without being able to see it as you suggested)
There are issues with X670 and Nvidia 4000 gpus, compounded by using the secondary hdmi port for display. its seems reading NVIDIA forums and youtube
Issue 1 - No display at all ever (4000+x670?)...nvidia provide a firmware update (i already had the fw update)
Issue 2 - No display on any ports on 1st cold boot ... turn off fast startup (windows power setting) (<i suffered from this)
Issue 3 - No bios display ..use primary hdmi not secondary hdmi port (you suggested this but issue 2 hid this solution to me)
thanks for help.
i was concerned given points above the non optical cable wasnt up to the task...but now i believe my powered cable is fine and the LS1200b is slower to lock on to HDMI signal.
next task... undervolting now ive have felt how much heat the GPU kicks out.
thanks for help.
