Baddass said:
can you take the extension arm out of your model? the one headrat showed in the first post is the standard arm, but the guy took the extension out like in the pics ive posted
what im trying to find out is whats the lowest the screen can go, and then how far out from the back of the desk does it stick. since my desk isn't that deep and i like the monitor quite low, i dont want it sticking out too far
Tbh I haven't tried taking it out...and I thought I had the standard arm(!). Mine hasn't got the third intermediate bit that links the two portions together to allow for the extra movement - mine is exactly the same as the one you posted on that pic with the Shuttle. I've seen that pic before on another forum, but I wasn't aware that he ACTUALLY took the arm apart to remove the middle link, I though he just bought it standard like mine?
My screens can be extended till the base of the screen touches the desk (with the arm still locked - the tft is not actually putting its weight on the desk). In fact, I believe any screen can achieve this, even the Dell 2405's. They are very sturdy but then again the Dell's are considerably heavier than mine so I'm not too sure how it will hold against a full extension...
A full extension on the one HEADRAT is getting
may extert more force on the joints of the arm because of the middle link adding extra horizontal length at full extension (I believe).
As mentioned before, on the ones I have, a full extension is only as long as the upper half of the arm when it is perpendicular to the lower half (which is about 30ish cms). The curvature of the lower half of the arm + the depth of your tft is likely to bring the total extension from the back to around 40+ish cms.
