esata help (noob alert)
11 Feb 2004
TheWirral
I have an eSata port on the front of my computer.
I wish to connect a desktop hard drive to it, to get some data off of it.
Do i just need an eSata to eSata cable to do this?
how does the the hard drive get power, is the eSata in my PC also connected
to the motherboard with usb to allow power for this very scenario ?
Cheers for any help.
I have two eSATA ports on the back of my machine. I have two cables both 2m long.
One is eSATA to eSATA and the other is eSATA to SATA ( female) . The latter allows me to connect a SATA hard drive to my PC. To power the drive you could either buy an external power supply or if your case allows by a extended 4 pin power supply and run it from the inside to outside your case. I use an external power supply.
Hope this info helps.
I bought my cables from that online auction site.
One is eSATA to eSATA and the other is eSATA to SATA ( female) . The latter allows me to connect a SATA hard drive to my PC. To power the drive you could either by an external power supply or if your case allows by a extended 4 pin power supply and run it from the inside to outside your case. I use an external power supply.
thanks for your help.
another option:
i can connect the Hard drive to my motherboard on "my" computer as long as i have the correct inputs, ie power cable and sata slot?
im sure my pc probably will?
Another option,
On that online auction site search for USB to SATA.
this site does not allow links to other sites that sell things.
Searching should show you a power supply and an adapter for IDE to USB\ SATA.
Buy an eSATA to SATA also then your good to go and be able to connect any drive to your PC.
thanks your help so far guys.
would this also work:
Allcam IT-735 USB 2.0 and e-SATA combo Enclosure for 3.5" SATA Hard Drives -Black.
Convert any 3.5" SATA desktop hard drive into an external hard drive in seconds, support both SATA-I and SATA-II
Attractive design with rounded corners and edges, cleverly designed front panel with all control buttons and connections for easy access
Inovative tool-free assembling design: two aluminium plates sandwiching the main chasis, maintain the weight low yet still heat transfer friendly, quick and easy to install hard drives
Dual high-speed interface: high speed USB 2.0 and e-SATA ports, full plug & play, hot-swappable
Support all major operation system: Windows 2000/XP/2003 / VISTA /Win 7/ Windows 8 (32-bit, 64-bit), Mac OS9 or higher, Linux Kernel 2.4.x or above
That looks nice.
I guess it comes with it's own power supply.
You would have to check what other cables come with it, you may well need to buy extra cables any way. i.e the eSATA to eSATA cable.
Is it expensive ?
That looks nice.
Is it expensive ?
£15.99 delivered.
You can use USB2 so i guess it can be powered from that.
Mmmmmmm powered by the USB port.
I can not defiantly say but I can't imagine a USB port having enough juice to power a hard drive.
On the caddy there are 3 ports and what looks like a power on light, to me it looks like the far left port is the power supply port.
Seems a good price. Go for it.
i share your skepticism lol.
I am going to email the seller and ask does it come with a power supply
and usb cables.
to be continued ....
