Hey,
I am in the process of having my 3 storey house wired up with an ethernet wall plate on each floor.
One issue I am finding is regarding the ethernet standards. 90% of wall plates state something similar to 'Ethernet wall plate Cat6' I want 6a or even 7 standards. The ones specified for this tend to be quite a bit more expensive but is there any difference? I know the actual cable used needs to be 6a/7 but as they all use the same connection ie RJ45 is there actually a difference. Will a 'Cat 6' Wall plate work at full spec with a Cat 6a or 7 cable?
