Why?If you want 10gbit, use fibre
Likewise, mix of 5e and 6 here. No probs with 10gb from garage to the loft over 5e.I have 5e about most of the place and I run 10 Gb.
Uses less power.Why?
And what about the client end with RJ45?Uses less power.
. Thinner lighter cables.
Future proof
Cost less than 10gbit ethernet port switches (which there is not many for a reason. Google 10gbit switches and they are mostly sfp+ devices)
And those are just some of the reasons I pointed out.
If its 10gbit you need, use fibre lc with sfp plus transceivers and you are good to go
Get a sfp card? Chances are the client machine doesn't have a 10gbit nic of any kind unless it's a high end motherboard.And what about the client end with RJ45?
Switch to switch runs should be fibre. Well, could be fibre.Get a sfp card? Chances are the client machine doesn't have a 10gbit nic of any kind unless it's a high end motherboard.
cat6a or 7 is fine for 10gb; the advantage of fiber is current prices of sfp+ switches is far less then 10gbaseTIf you want 10gbit, use fibre
And options for sfp plus switches vs 10gbit rj45 switchescat6a or 7 is fine for 10gb; the advantage of fiber is current prices of sfp+ switches is far less then 10gbaseT
99 percent of what your connecting to doesn't even have 10gbit nics so you still need to install a 10gbit nic of some kind to begin with.It's impractical to use as an access medium at home because 99% of what you'd be connecting in a house needs converting back to copper before it can be used, and the tooling required to terminate it is not something that many people have available to them.
Its called measuring.If I wire a house with Cat6 cable I can plug things I own into it. If those devices aren't 10GbE capable then they negotiate a 1Gb or 100Mbps link and work fine, also I can do PoE to them if required.
If I wire a house with fibre I can't do anything with it without e.g. a media converter behind my TV. I'm confused why pre-terminated cable would even come up in a discussion about wiring a house - what systems do you have in place for managing the many metres of excess cable and preventing the connectors from damage during the installation?
Exactly this.If I wire a house with Cat6 cable I can plug things I own into it. If those devices aren't 10GbE capable then they negotiate a 1Gb or 100Mbps link and work fine, also I can do PoE to them if required.
