Caporegime
- 7 Apr 2008
- Lorville - Hurston
You can combine the two. It's not one or the other.Exactly this.
For client runs, use copper. If necessary, you can use a 10 GbE module for clients which have a 10 GbE SFP+ based NIC in them. Anything over 10 GbE is likely going to be next to a switch which supports it, in which case use DAC as an example like most data centres do.
For switch to switch runs, fibre is good if the switches support that medium, ie, SFP+ cages.
It seems mad to me to put in fibre to faceplates around the house for normal clients to consume.
You can have a fibre and copper faceplate if need be.
As said, many client machines won't have 10gbit of any kind so you have to consider adding a rj45 or fibre 10gbit nic (the fibre nic is cheaper the last time I looked)
). Doesn't help the push for fibre internal network installation at home for those looking towards up'ing their network though with so many places providing info that's... not entirely accurate. *shrugs* Would certainly have given me more to think over back in 2014/2015, although I imagine I'll have stuck with copper anyway as there's limitations involved at my place (surface mount only), but it would have been good to know back then.
