I was originally planning to do this but after reading a bit I’m concerned about the risks of pulling that much power from a 3-pin socket. Especially overnightMy advice - and I have yet to get my own EV, it's coming in June - is to see how you get on with a boring old wall plug and decide whether you actually need to get a specialist charging box fitted.
A 13A/240V supply will charge an e-Golf completely overnight; do you actually need to be able to charge faster than that?
Obviously, if you don't already have a suitable external power supply in a good place for where you park your car, ignore me![]()
If you can put it near-as-damn-it/its own circuit it shouldn't be an issue. It draws closer to 10A and the granny chargers have thermal protection built in. I've been doing it for 2 years now.I was originally planning to do this but after reading a bit I’m concerned about the risks of pulling that much power from a 3-pin socket. Especially overnight
Yeah 1.3million bulbs instead yeah?There’s no technical reason the headlight cluster can’t have replaceable LEDs. It’s a cost saving measure.
Yeah they are always on and the blank zones are done with shutters so there’s also a mechanical element to the system.thats great... i didnt think you could do that with xenons. That makes them even better than i thought (and i was already a fan of them)
so what is their downside then? (energy use i guess?)
paddles will likely either be for regen or eco / power modes..... unless they have tried to copy why hyundai have done with that special edition ionic 5.Anyone seen the new 2025 cupra born?
They've added a bigger motor and it has paddle shift gearchange
pixcell/samsung ones as used in Model3 suspect you could replace board, but would first have to dismantle it, if it wasn't all destroyed in crash.I mean as a small cluster unit rather than an entire assembly. It would still be expensive but not £2400 like with the I-Pace
Low Beam:
F30/31 LCI Standard LED: 784 lm
F30/31 LCI Adaptive LED: 1097 lm
F32 Xenon: 1170 lm
F32 Adaptive LED: 903 lm
High Beam:
F30/31 LCI Standard LED: 1226 lm
F30/31 LCI Adaptive LED: 1498 lm
F32 Xenon: 1702 lm
F32 Adaptive LED: 1802 lm
It's petrol?The upcoming Tavascan also looks like a tasty looking car. It’s essentially an ID4/5 and Enyaq without the dullness
seems leds in bmw weren't always a performance upgrade -
I think the colour quality CRI in xenons is better too, leds look harsh with the blue peaks (whether you could grow grass with a led headlight ?)
On the contrary blue light is good for plants..Yea the high "temperature" LEDs have a lot of blue light, which is counterproductive.
Not sure it's that useful for plants either. The percentage of blue light from these headlights put out is a lot more than the sun emits (25% vs over 30%).
Do ypu not think that research has been done?
