Not everyone is going to buy a new Tesla.
Did I say there were going to, as I said that is one example.
Its a very specific and selective example. No ones not going to rock up in a nissan leaf and get that.
10% | 221 kW | 2 m 21 s | 7.4 kWh |
11% | 221 kW | 2 m 34 s | 8.1 kWh |
12% | 222 kW | 2 m 47 s | 8.9 kWh |
13% | 222 kW | 3 m 0 s | 9.6 kWh |
14% | 223 kW | 3 m 13 s | 10.4 kWh |
15% | 223 kW | 3 m 26 s | 11.1 kWh |
16% | 222 kW | 3 m 38 s | 11.8 kWh |
17% | 223 kW | 3 m 51 s | 12.6 kWh |
18% | 224 kW | 4 m 4 s | 13.3 kWh |
19% | 224 kW | 4 m 17 s | 14.1 kWh |
20% | 224 kW | 4 m 30 s | 14.8 kWh |
21% | 224 kW | 4 m 42 s | 15.5 kWh |
22% | 224 kW | 4 m 55 s | 16.3 kWh |
23% | 225 kW | 5 m 8 s | 17.0 kWh |
24% | 225 kW | 5 m 21 s | 17.8 kWh |
25% | 225 kW | 5 m 34 s | 18.5 kWh |
26% | 225 kW | 5 m 46 s | 19.2 kWh |
27% | 226 kW | 5 m 59 s | 20.0 kWh |
28% | 225 kW | 6 m 12 s | 20.7 kWh |
29% | 226 kW | 6 m 24 s | 21.5 kWh |
30% | 226 kW | 6 m 37 s | 22.2 kWh |
31% | 226 kW | 6 m 50 s | 22.9 kWh |
32% | 227 kW | 7 m 2 s | 23.7 kWh |
33% | 227 kW | 7 m 15 s | 24.4 kWh |
34% | 227 kW | 7 m 28 s | 25.2 kWh |
35% | 227 kW | 7 m 40 s | 25.9 kWh |
36% | 230 kW | 7 m 53 s | 26.6 kWh |
37% | 230 kW | 8 m 5 s | 27.4 kWh |
38% | 230 kW | 8 m 18 s | 28.1 kWh |
39% | 230 kW | 8 m 30 s | 28.9 kWh |
40% | 232 kW | 8 m 42 s | 29.6 kWh |
41% | 231 kW | 8 m 55 s | 30.3 kWh |
42% | 232 kW | 9 m 7 s | 31.1 kWh |
43% | 233 kW | 9 m 20 s | 31.8 kWh |
44% | 233 kW | 9 m 32 s | 32.6 kWh |
45% | 233 kW | 9 m 44 s | 33.3 kWh |
46% | 234 kW | 9 m 56 s | 34.0 kWh |
47% | 210 kW | 10 m 9 s | 34.8 kWh |
48% | 186 kW | 10 m 24 s | 35.5 kWh |
49% | 186 kW | 10 m 39 s | 36.3 kWh |
50% | 186 kW | 10 m 55 s | 37.0 kWh |
have you had any movement? I'm waiting for an update from the dealership, so far we were told early Dec, then mid Dec and finally just Dec. I could see it slipping to January.Cheers,I'll do the same![]()
Hi was going to come in to say - initial estimate of April / Mayhave you had any movement? I'm waiting for an update from the dealership, so far we were told early Dec, then mid Dec and finally just Dec. I could see it slipping to January.
Like I said if you dig a hole you don’t compromise. You need to listen and not just say stuff : Radio Pope. 25m is loads.Like I said I realise/think the existing 2.5 would only give 16A/3.7KW ...
- having seen that you can now get a reasonably priced CU with the appropriate PEN protection, that seems to open up a cheaper commando plug charger route for 7.4KW too, if you have a smart car.
I don't want to dig a hole will cost 4/5K if I & neighbours can get 3.7KW charging through existing wiring for £400 that would probably do me -Like I said if you dig a hole you don’t compromise.
Just get a granny chargerI don't want to dig a hole will cost 4/5K if I & neighbours can get 3.7KW charging through existing wiring for £400 that would probably do me -
listen to what no-one added anything to what I originally said I posted my summary to see if anyone knew any obvious pitfalls, obviously slightly unusual situation
True. Imagine how many whats he will generateConnect it to an exercise bike.
