- 27 Mar 2013
Ouch at -50 you won't be doing many long trips. Is the drop in range just due to the temperature and the batteries or factoring in stuff like heating seats/windscreen and incar heating?Just found this forum post today. It's a thread discussing the range drop of a Model 3 in cold temperatures (33% at -15C). One of the posters on the third page posted a table with their actual efficiency vs temperature which was interesting.
https://teslamotorsclub.com/tmc/threads/33-range-loss-in-cold-winter-conditions.106072/
I decided to graph it up to see the trend clearer (and converted it to Centigrade) (the last three points in the >25 Mile efficiency are extrapolations based on the trend line of the actual points). Outside of the anomalous 107.7% reading at 35 degrees there's a pretty good trend.
Now, for the UK it doesn't matter as much, temperatures only drop to -10 so maximum efficiency loss due to temperature would be around 25%. Not great, but liveable. For here temperatures get a bit lower which is why I did the extrapolation - I've never seen any actual data down to -30 or -40c. While it's probably not completely accurate at the extreme end it does tell a worrying story, suggesting to me that BEV's are not going to be a real option for a fair chunk of people unless we have a step change in technology (or come up with a way of heating batteries with a separate system). -30 isn't uncommon here, and further north -40 is common in winter. If that extrapolation is even remotely right something with a 300 mile EPA range at 10-30C gets a real world range of 100 miles at -35 (with pre heating of battery).
That also blows cost saving out the water as well. Suddenly electricity costs 3x the amount you think it would, and becomes far more comparable with petrol, even more so if you recharge at a commercial location rather than at home - which you'd have to do more as the range reduces so significantly.
And no, this isn't a theoretical study for me - the thermometer hit -35 a couple of times last winter during >100 mile trips. It does make me wonder if having a BEV as a primary vehicle will ever actually be feasible if I continue to live here. Even with the 350 mile BEV mentioned earlier I still wouldn't be able to do trip to my local ski hill without having to charge both directions when it's -30.
There may be solutions to this. Some people already use diesel heaters in their BEV's in winter to extend their range. Perhaps the use of similar systems on battery packs may help (although would be a bit comical) - alternatively (half joking admittedly) some form of radiation based heat like they use in space probes. Would be interesting if you crashed though...![]()
