- 19 Oct 2002
- Shakespeare’s County
thanks yes so they nearly doubled capacity , but battery weight only went up 25%
https://www.whichev.net/2019/11/21/...ing-you-need-to-know-2019-2020-race-calendar/
car weight impact
I'd like to see a an overlayed lateral G&speed for the Taycan, versus a 900+kg lighter, ICE sibling, on the Nürburgring
unless the Taycan has much bigger contact patch on the tyres, or, much lower CofG, it must be be able to go around corners, versus its sibling, limited by the ratio of the weights,
so the taycan would be 40-50% slower, yes it will accelerate faster on the straight, but that G feeling you get going round a nice corner/roundabout will be diminished,
a cars active downforce can impact this issue too, but that's going with square?cube? of speed.
Obviously that lower weight also means additional passive safety margin for the car leaving the road in the wet, say .... you can't overrule the laws of physics.
Why would you like to see that ?
What an utterly odd post - predicting a Taycan can limit G at circa ~0.6G is so wide of the mark its not even worth entertaining the discussion.
So has a double decker bus.
You were closer with bus, why edit to double decker? your not quite as punchy with your posts as you think.
Lets see, maybe 'cos its not a Porsche and doesnt demand the attributes associated with the brand. When exactly are you gonna wind your neck in - its so boring having the Masher report everyday.
