The issue with granny charging is usually the socket itself not the wiring behind.
If there is bad contact, it will melt eventually.
You can get EV rated socket facia that are specifically tested to a higher spec. They only cost a few £ so if you plan to granny charge regularly, I recommend a swapping to one.
I’d just granny charge, 10 hours a day you are getting 90 miles back.
