Sorry for another newbie question
My car as it's currently at the port awaiting delivery to the dealership. I’m holding off on getting a home charge point installed until I get official confirmation from the dealer that the car has arrived on site. In the meantime, my plan for the first few weeks is to rely on public charging points. A colleague recommended Zapmap.
For connector types : I keep seeing mentions of Type 1 and Type 2 (as well as CCS). Does it matter which public charger I pull up to? Will standard public rapid/fast chargers plug straight into a modern EV without any issues or adapters required?
- There is a Fuuse charger nearby listed at £0.70 (up to 360 kW).
- An InstaVolt a bit further away, but at my Gym listed at £0.85 (up to 160 kW).
Also do i need these app's of the provider, or can you just usually pull up and tap a debit card?
Zap map, Electroverse and the Tesla app for Tesla superchargers.Sorry for another newbie question
Yeah I think I'm just going to take that approach, it's never going to be mine. Plug it in and let it charge to whatever from 11pm to 6am.my wife's Kona charges until it's full because woman "reasons" but it's also on PCP so I'm not particularly fussed about babying the battery unlike the VW which I own but again easy enough to set and forget the limit in the Hyundai app and just let it do it's thing.
All rapids have contactless except some Tesla ones. And use CCS2 so you'll have no issues.Sorry for another newbie question
That bit is the easy bit I guess, but then charging out and about I think isn't as easy as plug car in, pay.It doesn't need to be complicated, but it's nice to have lots of features to cater for all users.
Using your mum as an example (mine would be exactly the same) set the car to 80% max charge which is a one off setting and set the charger to charge on plug in. Plug the car in, it charges to 80% and stops.
And home electric tariffs are hugely different I guess for low milage it isn't an issue but if the vast majority of usage is charging the car you might want a cheap overnight one.
It's crazy how it requires a different way of thinking after all these years of full up, pay drive off.
Literally just said how it could be easier. All charging points should be you pull up, plug in your car, chip and pin payment drive off when done, no apps.Out and about can potentially be more of an issue, unless you have a Tesla. But using an overnight tariff is far easier than filling up at a petrol station. It's no different to charging your phone.
I honestly don't know how it could be any easier.
The legislation already exists my friendLiterally just said how it could be easier. All charging points should be you pull up, plug in your car, chip and pin payment drive off when done, no apps.
Granted out and about is only a small fraction of the time, it needs sorting.
Home charging is more of you change to a EV tariff your then really needing to shift other heavy usage such as washing machine and dryer to night time or your wiping out the savings.
It seems like we need some legislation to force these companies to all just take a bank card to charge and no apps.
There is already legislation which requires this.Literally just said how it could be easier. All charging points should be you pull up, plug in your car, chip and pin payment drive off when done, no apps.
Thanks for that, seems it's not as bad as I first thought then.
Guess you still need to use an app, not really looked at Google maps to find suitable fast chargers no point pulling in and finding a slow charger when your in a rush.
Wonder how long before Google integrate that into Maps.Use an app like Electroverse for that. You enter in the details for your car so the app knows the range, start and end points the same as you would in Google maps and it'll calculate your route along with any charge stops required, click go and it'll send it to Google maps to use as the nav route.
Keeping the battery as close to 50% is best. If your usual use case scenario is 20%, then keeping the charge at 60-40% is best for battery longevity.Is 80% charge the best or is their a benefit to say 50% during the week I only do 50 miles a day then on a Friday charge to 80% for the weekend would be ideal that's when I generally do the longer 200mile trips.
