Not actually sure what's happening with my Octopus Go tariff, I'm still on the 13.45p/5p which started last Jan (15th I think). Not had anything yet from them to say it's going up though obviously it will, do they usually email?
Well this is rather rapidAmused me anyway - I thought of Bruce Willis's compliments to his adversary in the lift shaft scene - if the next bond film requires a green car, though
I drifted the new BMW i4 M50
What is it missing other than having a centre tunnel in the rear seats ?Imagine how much better it will/could be if they built it as EV from the ground up!
unless I missed it no plaidWell this is rather rapid
central tunnels have proved a bit divisive (in this thread too) the structural rigidity they inadvertently provide ( a spine?) helps the handling,
like the SUV format did to provide family accomodation, and keep the baby on board;
the fifth gear anglessey lap comparing 330e against octavia phev, did however show that 330e's 300Kg of additional weight didm't take the prize
e:
I believe it means "[h]e:s a ****"what even does an e followed by a colon even mean? “e:”![]()
the 330e/octavia phev duel showed the consequence of additional weight - which ev's have generally, and probably moreso ones with tunnelsOnly from weapons grade regurgitaters like you. What on Earth has a Skoda Octavia got to do with anything?
I assumed you meant it's slow compared to a Plaid in general, not what the guys at AutoTopNL have blasted down the Autobahn.it was an edit 'e:' to remark a pendantry what no tesla in the list
The main benefit for a ground up EV is the packaging, it should enable a larger interior/load space for the same size car. Sometimes battery size, weight and efficiency is impacted but that depends on the platform.
I’m sure BMW will do a ground up EV.Imagine how much better it will/could be if they built it as EV from the ground up!
Imagine how much better any version 1 product would be if they could make it like the v10 product.
With reference to the discussion on 3/4 SeriesThey just have, it’s called the iX. 9 years after the i3.
