£35 for 76 miles?
No as confirmed it is 49ppkWh, so it was £15, or just over for the amount charged.
£35 for 76 miles?
If it was a pre -auth charge at a petrol station it could have been £100+ for those two gallons£35 for 76 miles? that sounds awefully expensive; 40MPG car can cover that in 2 gallons thats just over 9litres of diesel even takign £2/L thats £18
using public chargers atm is about the same if not slightly more than driving ICE cars. 54kWH with 3miles/kWH efficiency on motorway thats 168miles thats about £33 wiht diesel cars or £30 with petrol.
for a long trip always home charge to the full and thats the only way of saving money over ICE atm
£15.33 for 31.3kwh. Let’s go with 3mile/kwh. Likely it does more. That’s 94miles for fast charging which will be probably 10% of miles if you have a home charger.£35 for 76 miles? that sounds awefully expensive; 40MPG car can cover that in 2 gallons thats just over 9litres of diesel even takign £2/L thats £18
35 quid to get me to 70% - mileage was separate number.£35 for 76 miles? that sounds awefully expensive; 40MPG car can cover that in 2 gallons thats just over 9litres of diesel even takign £2/L thats £18
That’s only for pay at the pump ones. Not if you pay at till.If it was a pre -auth charge at a petrol station it could have been £100+ for those two gallons
New work charger isn’t bad![]()
32 of them. It’s the staff carpark but the biggest U.K. charging hub. 24 7kW. 4 50kw and 2 300/4x 150kw. I’m confident the public ones will get better.You have one of the few working BP Pulse chargers in the country.
Any particular reason you want untethered? It's a PITA to keep bringing out a cable that can be 5-8ms long just to plug your car in at home.Would be un-tethered and as future proofed as possible.
My Energi Zappi does the solar really well from what i understand (aslong as above 1.4 of solar output) then excess they do the myeddi to dump excess into the hot water tank/cylinder if you have that.It looks like we're close to going ahead with the Model Y. What's the best type of house charger to fit at the moment?
Ideally, I'd like to get one where I have the option to limit the current if I wanted to charge via the solar panels, or full speed if we're using Octopus Go.
I'll be selling my PodPoint for a Zappi ahead of next Spring, purely for the excess solar function
