- 19 Oct 2002
- Shakespeare’s County
Are they the older SOLO2 round ones? Might just be old stock.
No - Solo3s...Are they the older SOLO2 round ones? Might just be old stock.
That should be pretty simple if you have a regular pension.I need to confirm pension impact on the scheme before anything else
The AC won't really consume too much battery power. Range will not reduce by too much. Remember there are still 12v batteries for some car functions.It's not particularly relevant to the UK - I saw it in the context of Americans evacuating Florida because of the hurricane - but EVs apparently have big problems during evacuations. You have a lot of people all travelling at the same time and while refuelling with petrol takes only a few minutes and you can carry extra cans of fuel, recharging an EV takes an extended time so there will be lengthy queues at recharging points when time is of the essence. Further, because of the need for air conditioning in Florida, EV batteries will discharge even when the car isn't moving (e.g. in a traffic jam) so their range is much reduced.
I believe that in the event of a zombie apocalypse knocking out the power supplies they are not very good to use as bug out vehicles. It is the same for self-defence against zombies - a chainsaw is good, but make sure it is not an electric one!Unsuitable for hurricane evacuation. Bit of a weird thing to bash EVs for tbh
What’s next nutcases?![]()
Average mi/kwh compare to kwh left. That’s how it’s worked out with the a heating/ancillary fudge factor. My range goes from 230 to 130 if I put the heating on full (5.5kW)I find the range estimate in electric cars absolute random number generators. So sensitive to change in environment. A bit like your ICE car estimation being over inflated when you come off of a long motorway stretch.
Yeah for sure but when you throw in regen and so on it can be very very misleading.Average mi/kwh compare to kwh left. That’s how it’s worked out with the a heating/ancillary fudge factor. My range goes from 230 to 130 if I put the heating on full (5.5kW)
That's why you fit solar panels to the roofI believe that in the event of a zombie apocalypse knocking out the power supplies they are not very good to use as bug out vehicles. It is the same for self-defence against zombies - a chainsaw is good, but make sure it is not an electric one!
In all seriousness, I take my wifes's ID3 to deliver daughter fro her golf lessons and I usually sit in the car for over an hour with it 'on' (AC, etc in summer, carplay on, etc), and I lose perhaps one mile from the range in that time.
