EVs will be taxed a chunk eventually anyway, when the whole world goes EV/other renewable, how else will the gov tax everyone?
I assume there will be a tax on them then an additional tax on ICE to make ICE more expensive
We could call it 'Fuel Duty'.
Solid state hybrids existed 20 years ago? Or did you also assume I was on about regular hybrids instead of the context of solid state.Is this post from 20 years ago?
Your sentence could have been from then, thats all.Solid state hybrids existed 20 years ago? Or did you also assume I was on about regular hybrids instead of the context of solid state.
so what is your goto app for route preparation and assessing reserve routes, remembering what you did before ....With an EV it's not as simple as planning a route and deciding to stop at charger A on the way there and charger B on the way back. You always need a backup plan because if the charger is in use (likely if it's in a convenient location en-route) or broken (far too common), then you either need to wait (potentially for quite some time) or have a plan B.
The need for a plan B means your plan A charger should be at a point where you still have enough range to get to the plan B if needed, so you're never using the full range of the car (e.g. you can't run down to 0 miles, because if your plan A is unavailable then you're ****, so you need to leave 20-30 miles to get to plan B (and C...etc.)).
Welcome to 2013 EVspoint is if you can only do 40miles before charging, even if charging is instant. What’s the benefit ? Solid state aren’t the magic a carwow video seems to state.
Plausible destinations: 0I used Zap-Map on PC to prepare the route in both directions, making sure there were backups within a couple of miles, and also making sure to choose sites with 6+ compatible chargers to maximise the chance at least one would be available*. I then saved all of these options to the nav in the car to make sure I could find them again easily.
I had the car fully charged for when we left, made sure to check where all the chargers were within a few miles of the hotel, and also to ensure we arrived with at least enough range to get back to the closest multi-charger site.
?Plausible destinations: 0
I used Zap-Map
Think Haggisman said he was driving to Cornwall from Birmingham I can think of a few spots where there are multiple sites fairly close to each other. M5 near Cribbs Causeway has a few, Ionity Cullompton and Moto Exeter are also not far apart.Plausible destinations: 0
That's a right faff!I used Zap-Map on PC to prepare the route in both directions, making sure there were backups within a couple of miles, and also making sure to choose sites with 6+ compatible chargers to maximise the chance at least one would be available*. I then saved all of these options to the nav in the car to make sure I could find them again easily.
Bear in mind this is an eNiro, which is up there with pretty much the longest range of an "affordable" family EV; ~250 miles in the real world. It's certainly not a trip I would want to do in something with shorter range, particularly the Zoe we had before which was limited to 22kw charging!
Basically quite a bit of planning, which isn't really an issue when you've been arranging the trip for a couple of months, but not ideal when you wake up early on a Saturday morning, it's a beautiful day, and you decide to take the kids to the beach.
Edit: to point out that none of the above would have been necessary if the hotel had a row of 7kw posts which could be pre-booked. We probably could have done the trip each way on one charge by dropping to 60mph.
Reliable and plentiful destination charging is (IMO) far more important than huge numbers of rapid en-route chargers. If the hypothetical 200 mile round trip to the beach ended in a carpark with a row of chargers then instead of having to waste travelling time stopping at services (and taking up rapid chargers which could be more useful for people on longer journeys), you could just plug in when you arrive, unplug when you leave with a full battery, and everyone wins.
* Well, the pub we stopped it actually only had a single rapid, but there was another site with 12x 350kw chargers less than a mile away as a backup
If you just want a straight route from place to place, ‘a better route planner’ is far better than zap map.
Put in your starting point, car and destination, hit go and it will give you a fully optimised route.
