- 19 Oct 2002
- Shakespeare’s County
Still mental current to drag through CCS.
People also have unrealistic expectations of fast charging. Most cars will not sustain anywhere near their peak for more than a couple of minutes - the more charged the battery, the slower it can take on more.
Yeah. I also found out the other day that superchargers use water-cooled cables so that the copper doesn't have to be so thick that the wire is unmanageableStill mental current to drag through CCS.
maybe trying to understand whether people have made efficient use of chargers (tangent ? discussion was about new chargers - so, will they be exploited)He’s on another planet. Just goes off on tangents posting videos and links he doesn’t understand and I’m not sure why
Indeed,Yeah. I also found out the other day that superchargers use water-cooled cables so that the copper doesn't have to be so thick that the wire is unmanageable
250KW @ 400V is 625 amps!
is 270Wh/m super efficient?What’s great about the Nero (and Kona) is that they are super efficient.
So while its charging speed on paper is pretty low, the amount of range you actually get back for the time you are plugged in is pretty good. It’s not that far off cars which charge much much faster.
How do you know what you were charged?Question regarding Intelligent Octopus.
I plugged my I Pace in last night and because I can't control the car via the Remote app I set the Pod Point to charge between 23.30 and 5.30.
The car has charged but the electic useage cost overnight isn't on the lower rate of 7.5p - Not sure what the rate was that it charged me but definately higher than 7.5p.
If the Pod Point charger schedule interferes with the IO schedule, would it stop IO from using the lower rate?
Next time I charge I'll turn off the Pod schedule and leave IO alone, see if it makes a difference. It's surprising how much of a pain it is not being able to control the car charging via the app.
Not efficient at turning electric into power though. They are tiny cars. Any power train will do well…
Really silly q but you sure you aren't looking at total consumption? 7.5p kWh but it could squeeze in 2kwh per hour hence it'd show 15p for that hour.Question regarding Intelligent Octopus.
up to 8kwh per hour actually assuming it charges at 32 amps.Really silly q but you sure you aren't looking at total consumption? 7.5p kWh but it could squeeze in 2kwh per hour hence it'd show 15p for that hour.
Pod Point doesnt work with IO, it relies on the car API handshake to enable the lower rate.
Aerodynamics ! Smaller car less drag. I got 3m/kWh in a ID buzz at 70-75mph which surprised me more!Yeah, I was very pleasantly surprised at the average 3.7 mi/kwh at motorway speeds!
Not quite as simple as that. Compared to the ZE 40 I had before, which was a smaller lighter car, it's far more efficient!
What is efficient is the context of ‘efficient use of chargers’?maybe trying to understand whether people have made efficient use of chargers (tangent ? discussion was about new chargers - so, will they be exploited)
I could repeat the practical issues in my own words - but if links/videos perfectly explain the issue might as well link them -
at work(OK - USA company, not a productive UK one) in engineering disciplines you build on the work of others
