- 23 May 2006
did you say your home isnt built yet.................. but they are NOT putting in a heatpump? FFS that is terrible (not blaming you, but your builder needs a kick in the nads!)Thanks for advice, will check the threads out. Seems like a nice saving to look forward to in future. I know we definitely dont have a heat pump but heard mixed reviews on them.
Just in the process on changing our old manual gas and electric meters to smart ones. (Selling home soon so not sure if its better or worse)
If its not broke, why fix it?
ANY new build with the proper insualtion will be a perfect fit for a heatpump and it is outrageous that new builds are going in with gas nowadays. if it were me i would be on to them asking / demanding a heatpump instead of gas.......
poorly fitted heatpumps in poorly insulated houses can end up being expensive, but in a new build? its as much a no brainer as solar panels imo.
