** EVGA Hadron Air Mini-ITX Case **
Will the integrated psu be sufficient to run the high end gfx cards?
What options do you have if you were looking to put a higher Watt PSU? Are you restricted by size?
Cheers
It will run a Titan and 4770k. Remember due to its size you cant add more PCI cards, so it will be sufficient.
Cheers
Looks like a rebranded SeaSonic SS-500L1U which is a 1U sized server PSU. There are some 700w models made by other companies, however I don't think they're 80+ Gold rated.
http://www.istarusa.com/xeal/products.php?model=TC-1U70PD8#.UmvEfxDiTwQ might be suitable with 4x 16a 12V rails but there's not much else.
Looks great until you see the 500w quality bronze power supply lol.It wont be bronze rated much when it is being pounded to 90% capacity all day long.
Even a corsair 500w in a high end system i would give it 2-3 yrs max before a cap blows.
500W is still a huge wattage, certainly in this system you wouldn't have space for CF/SLI. Not to mention multiple HDD's/multitude of fans etc etc!
And don't forget 'Bronze rated' is still 82%+ efficiency at 100% load. Gold is 'only' 87%+. Platinum isn't even 90%, but Titanium should be!
