Makes me wonder why they don't ship them with the blooming card in the first place.
Yeah that would make sense...
Do you only need to send the invoice to use RMA ?
I sent my invoice from OcUK to EVGA through the "my stuff" link. They say this helps if you ever need to RMA and will speed up the process.
Just had to scan and make it a PDF file.
Available for pre-order already from OcUK![]()
Just registered my 2 680's. Hope they send me two!(fingers crossed)
Just got email as I was typing "Thank you for registering your EVGA GTX 680 and requesting your free High Flow Bracket! You will receive an email soon with details on when it will ship."
Sounds good to me
Hi, I've just registered my 680 and these are still availableI figured they would have all been taken by now.
How do these backplates actually keep the card cooler?
They don't.
They do. Just like the metal plates on VRAM keep it cool where it would otherwise overheat.
Ofcourse, the difference is pretty minimal. As Andy said, the main use of backplates is for "structural support" and coolness (lookwise, not temps)
Is that why Nvidia and AMD fit them to all of their cards then?
I sense there's been a comms breakdown here
I was saying they do help with the heat (although not very much) and that's one of the reasons they are sold, but the main reson people will buy them is to make their cards look cool and keep them straight.
They won't trap the heat. The solid is a better heat conductor than air so it will take in the heat and it will dissipate it along the area of the backplate rather than the tiny components on the back of the card having to dissipate their own heat.
)"Thank you for registering your EVGA GTX 680 and requesting your free High Flow Bracket! You will receive an email soon with details on when it will ship." Thanks OP although I have no idea how to put this on, hope it comes with instructions.
The 4 nuts on the dvi connectors hold the bracket on and also normally a couple of screws on that face and another one on a corner connected to the shroud.
If it comes I'll rate EVGA so much!
