EVGA High flow bracket
If you wrap something in silver foil and place it in the oven it traps the heat. That's the whole idea, so the steam doesn't evaporate and dry out what you are cooking. That's also why you put a lid on say a casserole (lol this is funny as heck :D )
Thus, covering the back of your card (where heat rises from because hot air is lighter than cool air, see also - hot air balloon) will prevent the heat from rising out. The parts that touch the back plate? yes, things like the ram if they are touching it will dissipate their heat as they are in direct contact. But the board itself and the back of the GPU where all the heat is rising from will simply reflect that heat back in.
TBH that may have been a part of the reason the fail rate on the 260 and 280 was so high? I have noted that my 275 does not have a back plate.
I was talking about the metal bits that do make contact with the back plate :p
Probably from post #5 :P
lol. Blame Raven :D
:D
@overcrocker - there'll be plenty of room, the backplates are very thin :)
@elrasho - I was tempted as it seemed cheap to me aswell, but it's not really worth it as the cards barely worth anything after those 3 years! The 5 te extension did tempt me sorely though. With two cards, it's an easier choice as £60 to extend both cards to 10 yrs is quite a lot.
Looking at this step up program, is anybody going to do it? I am tempted to, so that when the 4GB comes out of even when the 780 comes out (maybe this year) I can pay the difference and upgrade?
or am I reading this wrong?
Er did you lot miss this bit ........4Gb ....ooh sir ! :D When the heck is that avalible if its based on the 104 rather than 110 ?:o:confused:
Next month I believe
you can't upgrade a 680 for a 680, there has to be a different GPU involved. You can do 670->680 or 680->780
Step-Up Information:
The EVGA Step-Up allows you to upgrade your product within 90 days of your original purchase date. For details, look over our Step-Up section under Support.
This product is not available for Step-Up. Please read the terms and conditions of our Step-Up program. :(
Anyone bought the extended warranty for 5 years (£16)?
Ahhh Ok cheers guys.
Nothing here yet, however I played Crysis 2 last night on ultra everything at 1080p with a custom fan profile and adaptive v sync enabled, i got up to 62degc after an hours gaming with 68% fan speed. Pretty incredible temps for such a powerful card.
Same settings on MW3 and the card only runs at 300-500mhz and 42deg c. So impressed with this purchase!
Although the bracket is a nice to have part, the stock solution does a great job :).
