My thermal pads have arrived, I requested them as soon as the option was available but hopefully the majority will also get them today. No signature was required, just posted through the letterbox.
Sod it mines going under water![]()
I put my superclock under water when I bought it. Pretty much just sits at 2Ghz all the time.
BTW you mightn't need to buy a backplate, stock EVGA one works perfectly with my EK block.
Were you able to use the EVGA blackplate with the EK block because the SC uses reference PCB?I put my superclock under water when I bought it. Pretty much just sits at 2Ghz all the time.
Fitted mines today, I did not put on their thermal paste but the Kryonaut, First time I put it back in the fan's did not come onit seems I did not put the connector all the way in!
This will be my first watercooling loop. How will I know if the backplates OK or not?
Question for you (as you appear to have done the mod already)...
From looking at the instructions from EVGA.
Point 2) It shows removing further screws shown in green after the base plate has been removed. In the case of the 1070/80 FTW, there appear to be another three screws highlighted.
IE. "Remove the remaining screws on the PCB (circled in green) ... "
But in the following video. He doesn't seem to remove any extra screws after removing the back plate.
Confused I am
PS. Not talking about the 4 screws that appear to hold the cooler on.
I haven't watched the video but on my 1070 SC I had an extra 5 screws underneath the back plate that needed removing (as stated in the guide). It all went quite easily, I just made sure I double read everything and it has all gone back together ok and hasn't blown up or anything![]()
Thanks for the reply.
Out of interest, what are these extra screws under the backplate for? Do they hold the middle cooling plate on? Or do they help hold the fan / cooler on?
Suppose I'll find out when I have a go.
