- 12 Feb 2006
- Surrey
badbob said:You could buy retail CPU and use stock CPU HSF for now. You can then replace the CPU HSF when you've paid the computer off and decided which is best.
Or you could buy OEM CPU and buy a CPU HSF straight away. OEM CPU's are cheaper, so the money saved can go towards the HSF.
And yes you do need CPU & GFX card HSF. Unless you have a really cool machine ie Pentium P200 where you can just get away with heatsinks, although a single slow 12cm is still needed to at least blow over mobo/ram/CPU heatsink.
As for PSU I would go for Enermax or Antec.
im so sorry but huh? im lost with all the cut down words, e.g. HSF, OEM, heatsinks?
Has the li-li v1000 case got 12cm fans included? if so are they any good? should i replace them?
ive updated my spec's again, with the asus board and i think nothing else
