Extension Cables for Rift S
Yes my double post! Was on phone probably didn’t respond as fast as I clearly would have liked!
No SLi (for the avoidance of doubt)
Rift S works fine without it
Just a few more questions, are you using a USB 3 extension cable as well? And when you try the Headset without the Rankie cable are you also taking out the USB 3 extension?
EDIT: what I am suggesting is you try the rankie cable on it's own, no USB extension. See if that works.
I use them both or not at all because the cables have to run differently. I want to use extensions because it makes it easier to disconnect the headset. I have read somewhere that plugging them both in before the PC boots is advisable?
will try rankie only and report back
