Hi
My brother has asked for help with getting his internet connection useable. He lives in a rural location, only wired option is really slow ADSL so he uses Three 4G. Connection inside the house is patchy as it's a an old house with thick walls.
I've had a bit of a look around and have suggested https://mikrotik.com/product/sxt_lte6_kit and https://www.ui.com/unifi/unifi-ap-ac-pro/
The SXT kit is based on me reading around but having no experience of actually using them. I am assuming it's not just a modem, and will handle routing and auth. My home setup is VDSL and my modem is separate, using an Edge Router for auth - so wanted to double check that a similar setup wasn't needed here.
Does this make sense, SXT will be mounted either on a pole or a tree - depending on cabling options.
