External device for hard drive
27 Dec 2018
I have few old hard drives with important data on them, these hard drives are not connected in side my pc but is there a way I can connect them externally so I can move important data from them??
Also these drives has old windows installed will this become a problem???
No, as generally you boot up then hot plug the drive in and its is found as a USB, you might have to seize control if the files you want are in a user folder, but that should be an issue
