External Hard Disk drive with Encryption
25 Sep 2011
I'm looking to buy a portable external HDD with encryption. Just after some suggestions.
HDD are still very expensive and I'm not sure when these prices are going to start coming down. i need between 500gb and a 1tb. This will only be used for storing pictures
thanks
Skippy.
iStorage/ DiskGenie Pin Code 256bit AES Encrypted/Secured External Hard Drive 500GB could be what you're looking for, pricey though
Could you not just Truecrypt the whole drive?
That's a much cheaper option
There is another option of just encrypting the data you require to be encrypted via containers
I use this on ALL my USB Memory sticks and it's never failed me.
However encrypting a whole hard drive would worry me as if the drive corrupted you'd basically have zero chance of recovering any files unless you backup of course :)
