So running eight units at 12v still gives a total 'cooling' capacity of 1260 Watts... even running all eight at 3v will give around 400 watts of cooling which should be enough to hold the cold side liquid temperatures at load.. (well lets hope so anyway!)
Based on the handbook here it's very important to avoid shear stresses in the ceramic when mounting. Since the mounting pressure is high and the plates inflexible, the tecs have to be exactly the same thickness. Melcor offer them lapped in pairs if desired to achieve this. I think you're using 8 pelts and two cold plates, so how are you planning on arranging these? I really like the idea of fitting a large number in the 5.25" form factor but am struggling to work out how to achieve this.
Surge - Do you have a build log or any information about TEC Chillers? I have only read about using direct contact TEC's.
snip..
At first i thought the bath WAS the extreme watercooling, will be keeping an eye on this thread.
Should make for an interesting build.
225 watt at 25c, with dimensions of 40mm? This sounds almost too good to be true, I'll look forward to your update. Cheers
Best found so far (feels like days of searching) 12711-5M31-15CQ at $26 a unit before shipping
At 4V, cop = 2, moves 20W for delta20
At 6V, cop = 0.66, moves 20W at delta30
At 6V, cop = 1.3, moves 43W at delta20
It's also a 40mm one, this appears to be the optimum for 6V. Any larger and cop falls too low as power drawn is excessive, any smaller and currents fall too far to move significant wattage. This has a qmax of 141, much lower than your 225, so I'm very interested in your find.
Further research suggests the 19915 is worth considering. I'm now sufficiently tired that I can't read the graphs though.
