- 4 Nov 2012
Still gets pretty hot with the stock cooler in games  . Seems to have settled around about 78 which is an improvement, then again this is with the overclock off. Saw similar drops with the overclock off with the cooler on. I'm going to order 2 SP fans to replace the AF cover ones today (Maybe this was a small issue? - some recommend SP fans for coolers), buy a replacement exhaust fan AF? and maybe put the 2 spare cover AF ones on the front as a replacement for the stock case intakes? Or should I buy some SP intake fans as it must travel through the dust filter and storage drive/stacks? Always feels pretty cool on that side of the case to be fair. If this doesn't make a shred of difference a new cooler will be ordered pronto.
Left the computer on over night (cooler back in with overclock back on) and my CPU idle temperature is 35, Motherboard 31, GPU 37, all 5 storage drives in the low thirties. Boot up is usually 25C when the comp has been off for a while. I had Steam running, Kaspersky, GeForce, AVG and now the browsers running to write this .
Will look into defaulting/updating that BIOS, hopefully I don't ballz this up and have to format Windows lol. Gonna have to do a bit of reading on saving/backing up profiles before I do anything though.
By the way thanks for the fantastic support .
. Seems to have settled around about 78 which is an improvement, then again this is with the overclock off. Saw similar drops with the overclock off with the cooler on. I'm going to order 2 SP fans to replace the AF cover ones today (Maybe this was a small issue? - some recommend SP fans for coolers), buy a replacement exhaust fan AF? and maybe put the 2 spare cover AF ones on the front as a replacement for the stock case intakes? Or should I buy some SP intake fans as it must travel through the dust filter and storage drive/stacks? Always feels pretty cool on that side of the case to be fair. If this doesn't make a shred of difference a new cooler will be ordered pronto.  Left the computer on over night (cooler back in with overclock back on) and my CPU idle temperature is 35, Motherboard 31, GPU 37, all 5 storage drives in the low thirties. Boot up is usually 25C when the comp has been off for a while. I had Steam running, Kaspersky, GeForce, AVG and now the browsers running to write this
. Will look into defaulting/updating that BIOS, hopefully I don't ballz this up and have to format Windows lol. Gonna have to do a bit of reading on saving/backing up profiles before I do anything though.
		 . Says something about AVG not being able to connect to the servers. Isnt that big of a deal anyway. I have 16GB RAM and all the options for live optimization, automatic maintenance have been turned off in the settings.
	 . I have bookmarked Disco P's Phanteks PH-TC14PE and Brazo's The bequiet 240mm jobby cooler suggestions if I at some point need them, will save myself the hassle of having to return <3.
