fornowagain said:The OP didn't even buy the card, it's second hand. And the original buyer bought it at OEM prices. He's lucky to get what he has.
But xfx do double lifetime warranties, so he is allowed a replacment.
Sure about that?jaykay said:But xfx do double lifetime warranties, so he is allowed a replacment.
Bomag said:It doesn't matter if the replacement card is £1 or £10k more, XFX have to stump up an equal or better product. It also has to be compatible with the rest of the system.
Shocky-FM said:If you seriously believe that the price difference has nothing to do with it then your just clueless.
Bomag said:Nice![]()
All that time I spent dealing with contract law has made me clueless apparently! .
Shocky-FM said:Indeed, welcome back to the real world..![]()
fornowagain said:Don't believe everything you read. No double warranty in the UK.
See what Gibbo has to say on XFX.
http://forums.overclockers.co.uk/showpost.php?p=8453034&postcount=50
http://forums.overclockers.co.uk/showthread.php?t=17715224Sean_UK said:Asus got cained in that quote too, did they change there ways unlike xfx then?![]()
Unless i am mistaken the 7800 series were all PCIE16 & youre mobo only supports up to x8 but in an actual PCIE 16 socket. You will likely get an 8600GTS, 79xx series card as a replacement if your card cannot be fixed (or get told its your fault & get nothing back) & it should work in the same socket any normal 7800 series card worked in. Only problem is if you get a replacement card youre unlikely to get one that will work in SLI with the other 7800 card you have.kinggost said:Wel cant i tell im going to have big problems becuase one of my sli 7800 borked today memory gone on the card. My problem is that i have 7800 so thye going to have to give me something newer and all the newer cards are pcie 16 and my mobo is pcie 8. So how will they go about this one.
dC2006 said:This is going slightly off topic but still relates to this thread. Just wondering why do companies offer lifetime warranties when they cant deliver a replacement product. Like in this thread it shows it screws up peoples SLI setups. False advertising if you ask me.
I had a smilar issue with some Geil ram (2 x 512mb PC4400 Ultra-x, Paid £159 well over a year ago). 8 months after purchase from OCUK it became faulty, contacted OCUK and they said they would take it and swap it or send it to Geil. Waited nearly 2 months then started chasing the matter up, OCUK said they didnt have any replacement in stock to send to me and Geil was telling them that they have stopped making the ram.
I am not blaming OCUK for anything but more Geil, all OCUK could do was offer me something similar priced, which at the time there wasnt much choice of due to DDR coming to an end and DDR2 becoming mainstream. So OCUK offered me 1 Gig of Pc3200 ram or £84.00 cash as they said they couldnt give the full amount.
Anyways I took the £84.00 cash refund and forked out more monies and got a new setup. It screwed up my overclocked opteron setup though which was running nicely at 9x315 1:1.
Just sharing my experience.![]()
FTM said:I'm guessing they will send you their closest replacement card as thats what they are obligated to do by the terms of their warranty..it wont say anything in their warranty about making sure it actually works in your motherboard or that it has to be backwardly compatible with your current equipment..I'm guessing it says closest equivalent value or performance of the card they are replacing
PAULV - 2007/06/26 said:Hi, thanks for your message and sorry to hear you are experiencing problems with your product. unfortunately it would appear that the item is faulty, however please try the card in another system to verify this. If problems persist and we do recommend you to contact your supplier for information on the returns procedure. But if you have any difficulties with this, please let us know. Thanks Paul
Azrael1 said:Its when things like this happen, you understand why people pay more for EVGA or BFG.
I'll def pay more for cards now with better service.
