just look at the BMW there from only a few years ago to see the difference.
I thought that too. Just compare that to now.
From a frontal impact the drivers head isn't going anywhere. It would be better to work on helmet technology.
I'm sure you're old enough to remember the time when an F1 driver snuffed it at every other race![]()
Your talking about 'something' in front of the driver that is strong enough to deflect a 200mph wheel and tyre... its hardly going to be an almost invisible cosmetic tweak is it?
I wonder if windscreens on any GT cars or LMP cars could even withstand that impact?
I don't think "how it looks" should ever come before driver safety.
Where are the wheel tethers attached? They seem to do a pretty decent job when a car crashes into a wall or something, but there was that incident in China a couple of years back when the Toro Rosso lost both wheels under braking when the suspension failed.
What's wrong with trying to give them more protection? Do you want to see their heads stoved in by tyres or debris? Just because you think it hasn't happened before, as has already been proven wrong, it doesn't mean it won't happen in the future. Odd.I'm pretty sure the 'wheel parachutes' idea was in jest.
they should do the test again with the canopy traveling forward at 180mph when its hit.I don't see any problems with canopies, that test already showed it can deflect tyres and can do the job.
whats the point in shooting something at a static object? theres mo than twice as much force when both objects are moving towards each other
why dont they just put the car inside a huge bubble incase something extremely rare that i dont believe has ever happened in f1 does happen.
i thought it ghot flipped up in the air and forced the oposite way to what f1 cars drive the circuit?Firstly, in what situation is anything in F1 going to be doing 180mph in opposite directions? Everything is travelling in roughly the same direction. Even the Massa spring impact was with a spring travelling in the same direction as Massa at probably near 100mph. It wasn't flying towards him, he just caught it up.
