Hi All,
Need alittle advice.
I have a Raid 0 setup using two 2TB identical drives. after an unexpected boot one of my drives are coming up as None Raid Member causing my raid to fail. The Drive has not failed! it is just the raid that has failed.
Is there a way to rebuild the raid without losing all my data?
The raid is on PCI raid card. I can clearly see, when going into options that one of the disks are part of the raid and one is not.
The only options I have in the raid manager are to
Delete the Raid
Convert HDD to none Raid member
All other options like Create Raid or resolve Mirror conflicts won't allow me to do anything as they aren't relevant.
Any advice from someone that has managed to rebuild a raid would be great, thanks!
Delete the Raid
