** Fallout 4 Next Gen 2024 - MODS & TWEAKS **
Caporegime
8 Sep 2006
On Ocuk
First Steps
C:\Users\yourusername\Documents\My Games\Fallout4
Fallout4prefs.ini ( Change this to your resolution if the launcher isn't working )
iSize H=1440
iSize W=3440
bFull Screen=1
bBorderless=1
bMBEnable=0
bDoDepthOfField=0
Fallout4Custom.ini:
[Archive]
bInvalidateOlderFiles=1
sResourceDataDirsFinal=
Fallout4.ini
[General]
sLanguage=en
uGridsToLoad=5
uExterior Cell Buffer=36
bDisableAllGore=0
bAllowConsole=1 <-- Add this
In Game
  • FOV FIX
Open your console in game by using the ~ key during gameplay
Type 'fov 95 95' (or whatever your FOV pref is), press enter
Then type saveini in the same console and enter ( It should stall for a second as it saves )
Then close the console command option
Main Install ( When installing mods, always make sure to load the game via F4SE! )
  • Vortex Mod Manager ( MUST HAVE FOR INSTALLING ANY FALLOUT 4 MODS ).
Vortex, the new mod manager made by Nexus Mods.
  • Fallout 4 Script Extender (F4SE)
The Fallout 4 Script Extender, or F4SE for short, is a modder's resource that expands the scripting capabilities of Fallout 4. It does so without modifying the executable files on disk, so there are no permanent side effects.
  • High FPS Physics Fix
Untie the game speed from the framerate. Fixes physical bugs. Reduces loading time.
Graphics Mods
  • Vivid Fallout - All in One - Best Choice
Vivid Fallout is an overhaul of all landscape textures, but also trees, rocks, roads, bridges and some concrete stuff.
  • Vivid Fallout - Trees - Best Choice
More performance friendly than original textures while being 2k!
  • NXGEN - Nice Bush
Replaces the forsythia and hedgerow bushes in the game with ones of much higher quality.
  • Roads Redone 4K-2K
Completely overhauled asphalt roads with new high quality 4k or 2k textures (Pick 2K option)
  • Vivid Fallout - Thicket Excavations Quarry 1k-2k-4k - Complex Parallax Support
The long overdue overhault of the marble quarry in 1k, 2k, HD and Best Choice size.
  • Vivid Fallout - Armor Workbench (Workstation) 1k-2k-4k - Complex Parallax Support
Time to improve the good old workbenches. Made them more rusty and worn down. As always in 1k, 2k, HD and Best Choice size. Reduced V-Ram usage for 1k and Best Choice compared to original.
Creatures/Wildlife
  • Wasteland Creatures Redone - Retexture Compilation
2K Diffuse and Normals
1K Specular Maps
Performance friendly
True to Vanilla textures
Clothing
  • FO4FI HD Series (HD Vanilla Armor)
This mod improves the armor quality to HD quality. This mod is better than HD DLC textures
  • FO4FI HD Series (HD DLC Clothes and Armor)
This mod improves all armor and clothing from ALL DLC to HD quality.
  • FO4FI HD Series (VaultSuit)
This mod is the first of a series of mods to improve the original textures. This mod improves all VaultSuit textures from the original game.
  • FO4FI HD Series (HD Vanilla Clothes)
This mod improves the look of ALL Vanilla clothes to HD quality.
  • FO4FI HD Series (HD Power Armor)
This mod improves the PA (Power Armor) quality to HD quality.
Sky/Weather Mods
  • Vivid Weathers - Fallout 4 Edition - a Weather Mod and Climate Overhaul
  • Better Moons
Immerse yourself in the beauty of Fallout 4's universe with a mod offering 4K and 2K texture variants for the moons Masser and Secunda
PIP BOY Mods
  • Improved Map with Visible Roads
A much better high contrast world map with roads, topography, and waterline all clearly visible. Optional number grid and regions.
Performance
  • Insignificant Object Remover
Safely removes insignificant objects to improve performance without visual degradation.
Lighting Mods ( Recommended )
  • Enhanced Lights and FX
Enhanced Lights and FX has the goal to create a more atmospheric and realistic lighting. It overhauls the lights, effects, ambient light and creates a new mood for interiors.
ENB (Personal Preference)
  • DECENT ENB gives you natural image and good performance.
((Vivid Weathers. Make sure the option "Natural Bright Colors" is chosen while re-installing Vivid Weathers))
Good stuff. Hopefully will be in good shape in a few months once I have completed Baldurs Gate 3 and Wasteland 3 :)
I'll be keeping an eye on this thread as ive never played this game.... will I actually play it this time around? Probably not but installing mods is fun haha
Not to deny anyone their "fun", but for the rest of us we now live in a post-Wabbajack world and can leave that kind of "fun" to the modlist authors
First change that needs to be made if widescreen isn't working ( Native is broken )
Fallout4prefs.ini
iSize H=1440
iSize W=3440
bFull Screen=1
bBorderless=1
If you have Geforce Experience, or the Nvidia App... Use the sharpen filter as the game is a little blurry!
Is F4SE required for all mods because I've got a few texture mods but haven't noticed any difference, is it because of F4SE :) ?
Scripting Extension should not be required for texture mods.
Even games which make it hard to do mods (aka those where the developer does not rely on the modding community to fix almost all their bugs!), generally have texture mods.
Sure does!
I'll only post next gen supported mods... So far graphics ones are fine :)
Might want to post the mods in the first post as well, since if this grow the half size of the Skyrim mod thread, it be a pain to find all mod suggestions ?? :p
  • Like
Reactions: TNA
Temped to play this rather than Baldurs Gate 3 which I fear if I start and get into I won't be able to stop until I am done and will be with it until Xmas :cry:
Also make sure you have enabled modding by adding following lines into Fallout4Custom.ini:
[Archive]
I will do, once the main FSE is updated :) - For now I'll be posting mods under it, then do a big update to the OP :) :D
