Fan replacement - Need help - R9280x
24 Nov 2012
UK Nottingham
Hi all, its been a while since i was last stumped like this, thought i would turn to OCUK for help =)
Cutting to the chase i have this card
GV-R928XOC-3GD-GA
(rev. 2.0)
Always had high ish temps so fans were wound right up. They started to get rather noisy so i ordered replacements. could not find exact fans advertised so bought some i thought id be able to make work (aesthetically they are identical)
Fans on card currently
1x 3pin - Everflow : T128010sm
2x 2pin - Everflow : T128010sm
Both above are DC12V rated at 0.20AMP
now, me being stupid just went on the fact that the ones i bought looked the same..........
so i ended up with
4x 4pin - Everflow : T128010su
Both above are DC12V rated at 0.35AMP
I am trying to find out if the car its self has enough juice on the fan output to power these, and if so, can anyone help with identifying what wires do what so i can change the pins to either 3 or 2.
If nothing can be done and the mods dont object (as i dont think they sell replcaement parts to this extent.) Can someone maybe link me or pm me if they know somone/somewhere that sells these.
Thanks in advance =)
